Question / Help advanced audio properties - monitoring audio disabled by default
crus
I used OBS for 3 years and monitoring audio setting in the advanced audio settings tab was set by default on (i'm translating from italian): "monitor audio and send to exit channel"
now it is set on "disabled" by default everytime and since i have to add many scenes on the go for my event i always have to set it manually while the scene is running.
Is there a way to change the default setting for this specific option or change it before the scene goes live in some way?
Thank you.
