At my wits end. OBS dropping frames due to Encoding Lag on a 4090.
Absolute butter. Even when I cranked up the resolution. Will need to run a few more stress tests at higher framerates, but this totally changes the game for me.
Thank you so much, @rockbottom. If you have a Kofi or something I'd love to get you a coffee. Much appreciated.
For Singleplayer UE5 games, I think I'll still probably force 1080p/60 through nVidia settings. For my main game, HUNT Showdown, I need the extra visual clarity, so I gotta gun for 2k. I don't usually record during HUNT streams so I have a little more headroom.
Still lagging, still carrying wwwwaaaaayyyyyyyyy too much baggage. Baggage that may or may not be bugged.
Forget 144HZ when using OBS. 60, 120, 180, 240, 360 .....
New Scene Collection, add (1) Source. Test
This isn't horrible but should be better. CPU may be getting a bit overloaded here & there...
09:25:05.459: audio_thread(Audio): min=0.004 ms, median=0.128 ms, max=386.62 ms, 99th percentile=7.676 ms
This needs to improve....
09:25:05.459: obs_graphics_thread(16.6667 ms): min=0.038 ms, median=0.729 ms, max=432.926 ms, 99th percentile=12.488 ms, 99.5727% below 16.667 ms
09:25:05.459: ┣tick_sources: min=0 ms, median=0.105 ms, max=184.573 ms, 99th percentile=0.275 ms
09:25:05.459: ┣output_frame: min=0.031 ms, median=0.525 ms, max=390.147 ms, 99th percentile=12.233 ms
You have a conflict on your system. Adobe CC most likely, needs to go when OBS is open.
Look at all those memory leaks, plugins/filters. Might go away with the new collection
Troubleshooting is the only way you're gonna solve it.
09:25:05.829: Blocked loading of '\coresync_x64.dll' 6 times.
09:25:05.829: Number of memory leaks: 602
