The "Filters" window - it has static size for the left part of the layout. It is like this since the first implementation of this part of UI. Only right part (preview and properties) can be adjusted (by vertical). So, this is by design. You can try to request new feature in: https://ideas.obsproject.com/ or if you see it as a bug, then try to fill-out the new issue in: https://github.com/obsproject/obs-studio/issues
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
