Breakpoint error (0x80000003)
evacuation_guy
Hey everyone, posting on behalf of someone else. This breakpoint error crashed her stream 3 times today and has crashed streams in the past as well. We've made sure that the audio sample rates are the same across every device and had minmal programs running while streaming. Any suggestions where to go from here?
Log file: https://obsproject.com/logs/2IvA529FB4c1mq5I
  • Log_File.txt
    Log_File.txt
It is very short crash log. All are the same?
It would be nice if you could monitor (via Task Manager) the amount of RAM/VRAM consumption during your streaming events. Maybe some application consumes it too much and nothing left to OBS (or maybe there is memory leakage because of mistakes in the software). OS can allow for OBS a bit more RAM usage if OBS running at higher priority, above normal (OBS Settings > Advanced > Process priority).
