Framerate drops when recording in 4K60FPS
Crazyreyn
Hello! I'm experiencing unexplained framerate drops when recording (not streaming) in 4K60FPS using an Elgato 4KX. The CPU usage remains low throughout (around 5%) and most of the time the videos record fine, but then you have a stretch when the framerate drops really low (I've kept an eye on the CPU usage and can't see it dropping at the same time), and I can't figure out why.
Example of what happens in the footage: https://youtu.be/ja04RfoOZ2s
OBS log (this is of many short videos back to back - I noticed the severe drops in the final two videos): https://obsproject.com/logs/Mlp4hbEj8OmHTcDu
Hardware:
  • Macbook Pro, M3 Max
  • 36 GB memory
  • OS: Sequoia 15.5
  • Capture device: Elgato 4KX
Finally, my OBS recording settings are attached in screenshots.
Let me know if I need to provide any more information. Thank you in advance!
