Question / Help how To record the Nvidia freestyle filter
Go to your game capture or video capture source right click, go into properties and scroll down and check "Capture Third-Party Overlays".
Hope this helps, worked for me playing on Guild wars 2.
Created an account just to say THANK YOU! Spent the last half hour looking around for a solve to this issue. The setting i had set up for my game just would not show up on stream. So clicking that solved the issue! Thank you again!!
Not working for me, I am still getting white stuttering only when filters are on, help !
Me neither. Has anyone found a fix? I've literally wasted hours to search for an answer for such an easy and probably common problem, and I still haven't found anything. So far the only thing that works is display capture, but is that really the only option? Can't I record the game with the filters in full screen game capture?
