Linux does not show the virtual camera offline screen
cooldudeseven7
In Linux, (specifically Linux Mint 21.2,)
The virtual camera offline screen (see attached image), does not show. Instead, it completely disables the virtual camera source. If an app was using it as a source, the camera just freezes. When you turn it back on, (lets say that I turned it off while using Zoom) You need to restart the Zoom app if you want the source. (Addition: If you restart the zoom app while the OBS Virtual cam is off, it just uses any other camera that can work.)
Do you have any things that could resolve this?
- thanks, cooldudeseven7
