Question / Help My Recordings/Streams Looking Super Blurry
AlePlayzYT
Hi, I'm a current Twitch Streamer and have been encountering problems while streaming the main game i play Geometry Dash (or any other game in general).
Let's say I'm on a menu the recording looks fine! (like image below)
I enter a level or something and my recording eventually starts getting really blurry. (like image below)
I really would like some help cause it is incredibly noticeable and it's starting to get annoying.
Log File: https://obsproject.com/logs/sqv7dAmxVUrHSQnb
My PC specs just in case:
Thanks In Advance,
AlePlayzYT on Twitch.tv
14:39:53.403: [x264 encoder: 'recording_h264'] preset: ultrafast
You've chosen the fastest CPU preset for encoding. This produces the least system load, and the lowest quality.
When you're on a screen with no motion, this is fine.
When there is fast motion, your stream will become pixellated.
For higher quality, use a slower preset.
If you can't use a slower preset, you'll need to reduce resolution and/or framerate until you can.
