Question / Help OBS Browser Plugin - No interaction possible
uli1966
when I use the browser Plugin an choose "interact" a Windows cones up, but I cannot scroll up or down. Clicking on a link works. I habe the problem with all webpages.
Any ideas what I can do? There are no controll buttons.
OBS Version 25.0.4 / Windows 10
Thank you so much for your help
Uli
Uli
Hey Uli! Try removing
CSS:
overflow: hidden
from the Custom CSS field in your Browser Source properties. If you have this set it will block scrolling in the Interact window. Just clear the CSS field or remove that specific line and scrolling should work!
Steps -
Click on browser and click on properties
Scroll down to Custom CSS field and remove the line mentioned above. It should work!
