OBS still says "OBS-NDI" detected even though I deleted it and every other *NDI file
mikeruel
OBS still says "OBS-NDI" detected even though I deleted it and every other *NDI file ... so I'm still dead in the water and can't get any NDI source from another computer on our network to feed into OBS.
I have installed DistroAV as the new plug in, followed their instructions to the T, but it will not launch bc it still thinks I have OBS-NDI installed.
If anyone has any ideas, I'd greatly appreciate the help...thanks.
I should add I have uninstalled and reinstalled OBS uninstalled and reinstalled DistoAV, emptied the trash, and restarted about 10 times
Did you go into library and delete it from the OBS folder? If yes then you'll have to uninstall DaVinci Resolve if you have it on the machine. That solved this issue for me.
