Bug Report obs-studio don't stop recording on UHD
fabrixx
Hi, I installed obs-studio on Arch Linux. I have an UHD monitor (3840x2160) and after start recording i can not stop it. It always stuck on "I am finishing the recording" the cpu work but does not end, even for records of a few seconds. Tried output HD (1080) but have no results. no video is generated.
Change to simple output mode, indistinguishable recording quality, flv format, software low cpu use encoder.
I need high quality and find solution: i have to install libx264 and remove libx264-10bit.
Now all work well
