animalshadow
animalshadow submitted a new resource:
Pomodoro Pro Timer for OBS - The Customizable Pomodoro Timer for OBS
Elevate your streaming and productivity sessions with our Customizable Pomodoro Timer, exclusively designed for OBS. This intuitive and adaptable script helps you implement the renowned Pomodoro Technique directly into your live streams or recordings. Break down your work into focused intervals (traditionally 25 minutes), followed by short breaks, to maintain concentration and creativity.
Features:
  • Customizable Durations: Tailor your focus, short break, and long...
heyy i just tried your script and i really love it. is there any chance that it could include like a session text as well per rounds of pomodoro like this?
Could you please tell me how to get it into a scene as a source?
download the lua file on his acc. it'll say pomodoro.lua > open obs > click tools along the upper left half > Click scripts> click add or + button > choose the file pomodoro.lua make sure that the title of your source is the same as the name of your pomodoro, so change the name of your text source as "timer" to match your pomodoro. then you can adjust accordingly
Hey everyone,
I just made my own version of a Pomodoro Timer for OBS. This version is based upon this script here.
Here’s what’s new in my version:
Reordered Controls: The Start and Stop buttons are now at the top of the settings panel, making them super accessible during live sessions.
Auto-Stop on Max Sessions: The timer will automatically stop once you hit your preset number of focus sessions.
Fast Mode for Testing: For those times when you don’t want to wait forever, Fast Mode lets you run the timer at an accelerated pace (1 real second equals 1 minute).
Customizable Durations & Messages: Adjust the focus, short break, and long break durations, along with personalized messages.
Sound Alerts: Get notified with a sound alert during transitions—just set up your media source, and you’re all set.
Check it out: https://obsproject.com/forum/resources/pomodorotimer.2094/
Cheers,
Paul
hi, how to view this script on the scene? I don't see it :(
first, add a source and then title it with something like "Timer" or "pomodoro". go to the "tools" att the upper left menu and click scripts. there you can see the + button and click and add your pomodoro.lua, entitle your source the same as the one you added earlier. it must be the same or else it will nott show up
animalshadow updated Pomodoro Pro Timer for OBS with a new update entry:
Pomodoro Pro Timer – New, More Reliable and Feature-Rich Version
This new release brings major improvements in reliability, control, and user comfort:
Improved Reliability
  • Verifies audio files exist before attempting to play them.
  • Non-blocking audio handling to prevent freezes.
  • Protection against invalid or illogical settings (sessions, minutes, etc.).
New Features
  • ON/OFF toggle to enable or disable sounds.
  • Mappable hotkeys in OBS: Start, Pause, Resume, Reset, Skip.
  • Auto-Start per Scene mode...
New Features
can you help me with a problem?
i downloaded, and followed the steps in readme.txt, it works except the timer is going wayyy too fast. 4x faster than real time. so 1 minute is finished in 15 seconds.
do you know what might be the problem and how i can fix it?
thank you so much =D great program otherwise
I'm having the same issue. Not sure how to solve it, but hoping a suggestion will come up.
