Random Playout
Random Playout 2024-01-28
Firetime
Firetime submitted a new resource:
Random Playout - Playout script that selects random media from a text file
Explanation
LUA script that converts OSB into a random Playout application. After each show it displays a schedule of the next three upcoming shows with a random background music track. After the schedule it plays a short moment of Zen/interlude video before starting the next show.
Setup
Create three scenes in OBS:
  1. TV
    • Scene must have a Media Source object that will display the shows.
    • Recommend using "transform > Fit to screen" (ctrl+F) on the media source if the...
Thanks lot for your great script. It runs on my iMac and it is a real improvement. I like this script!
One question or better a change: The videos will now play in random order, could you build a checkbox for random oder ordered run? This would helps. I think you 've at the LUAscript these math.random functions which are responsible for this, but I've no knowledge.
Hi Firetime, many, many thanks for the "current id" :-) It works and both version have PRO & CONS, but for me is the linear much better. The txt files are now the "control instance". The creator/streamer decide which video is frist, second, third... and this is more control in the workflow. Great script and I really like it. Many thanks again.
...perfect tool. And I can write the txt file easy with Numbers, Excel i.e.
Awesome, glad it works for you.
Also for anyone on windows needing a way to generate the file lists quickly if you open a folder and paste the following command in the address bar it will create a list of files in that folder and sub folders and place the absolute paths into the clipboard. Just paste that into your media text files and add the additional meta data as required.
cmd /c dir /a:-d /s /b | clip
This is a modified version of the command from a nextofwindows article.
Hello @Firetime
I know this is about a year old now, but this is a really awesome script you have here. I am going to be using it for a 24/7 live-stream.
May I possibly suggest a new feature? If you could make an optional text field that shows the name of the song playing on the schedule screen, that would be awesome. We would like to have one on ours but are not sure how to go about it. Maybe it could just spit out the file name onto a text box, without the file extension showing.
Thanks for all of your hard work on this. It's really awesome.
Sorry I haven't logged in here in some time. I've attached a version with an extra field for song title. in the music list file add the track title after the song path with a semicolon between.
ex:
music/song1.mp3;Song Title
