Sources dialog box does not minimize. Tried restarting program, still no fix.
Twitchfingerz
Have attached screenshot of issue and log file. This was the first time loading OBS since I installed it on my new pc. On first run everything was normal but I had to add the source, once I did that the box does not go away. Log file is of first run.
  • 2023-04-14 11-34-37.txt
Double click the title bar if you don't want it as a floating dock. If you accidentally undock things, you can use Docks / Lock Docks to prevent this.
