TeeBoard
Free TeeBoard v0.1.5 beta
Hi. I'm having problems installing this. I receive the following notice:
The application could not be installed because the installer file is damaged. Try obtaining a new installer file from the application author.
Please help.
Please help.
There's nothing wrong with the installer. This usually happens if something is wrong with Adobe AIR and/or your system. There's a Microsoft tool called FixIt that often helps:
http://support2.microsoft.com/mats/program_install_and_uninstall/en-us
Hey there DeezjaVu! Any chance that there are any updates in the cooker? Maybe something to find under the Christmas tree? Dem giveways and ticker tapes look mighty enticing ;)
I have a problem. The flash clock and countdown widgets have stopped working, they don't even work by opening the html or swf files with a browsers (I.E. and Chrome), just get a blank grey box. The poll/chat/notification ones seems to work using the same method, just not Clock or Countdown
I have tried deleting the files in my document, they were recreated still not working.
I have download the "other browsers" flash for CLR in OBS, blank there also.
I have uninstalled TeeBoard deleted the folder and re installed
Any ideas?
Any ideas?
Same problem
Any ideas?
No clue. All widgets work as intended. Widgets shouldn't just stop working, unless there was a TeeBoard update and I messed up. But since there hasn't been an update, I don't know what could cause them to stop working.
If you can't get things working, contact me here:
https://sites.google.com/site/deezja/contact
Hi.
I have downloaded the newest version of the tool.
version 0.1.5
As soon as I start it and click on the picture reads, "Connect with Twitch" nothing happens.
Actually, I should now confirm anything but nothing happens. It is as if there is no function behind the graphic
Has anyone an idea?
Hey, I recently got a SSD and reinstalled OBS/TeeBoard and my chat worked fine before this but now I can't change any of the settings. Its just the default red with black text glow. Suggestions? I've tried deleting the chat folder and letting it reset to default but nothing works.
Is the donations widget supposed to be working? Whenever I try to add my Streamtip account, it gives me an HTTP Error pop up.
Which location did you install TeeBoard in?
