Tuna
Tuna v1.9.11
How do we only show a certain key of the json_compact I am wanting to show the title for this json object so I tried {json_compact.title} this didn't work.
You can't it just outputs the json as a string, if you want to get a specific part you have to either parse the json in the text file or
Also how come we can't put more then one variable command for spotify! I use to be able to add song name and artist! using this {title} by {file_name} now I get an red error saying "The selected music source does not support one or more of the used format opitions!".
Spotify doesn't support the filename option
Hello, Im trying to install the Tuna plug-in, i tried the zip file version where i just copy and replace the folder within the obs folder, then i check my obs, no tuna plug in was found under the "Tools", then i also use the installation version, which also doesnt work. I'm don't know how to fix it, please help.
Thanks.
Thanks.
You have to update to obs 28
I've been trying to install Tuna on Ubuntu version 18.04, and once I had it installed it didn't work. The .so file was where it needed to be. But when I opened OBS Tuna didn't detect me. Both are the latest version. To contact easier and faster through Discord if possible: ikerr.#2223
Ubuntu 18.04 isn't official supported anymore. You need obs studio compiled with qt6 for the plugin to work.
Is it normal for the Tuna plugin to write the cover every second when there is no active music playing? As soon as the corresponding source is active, it stops constantly writing.
How do I compile the obs with qt6?
Idk, try https://github.com/obsproject/obs-studio/wiki/build-instructions-for-linux
I can't reproduce this. The reset cover function is called once and the cover is not updated until the song changes. Neither the creation or last modified timestamp change.
Hey any idea why when i try to install it in ubuntu 20.04 with Gdebi say this?
E: tuna: changelog-file-missing-in-native-package
E: tuna: description-starts-with-package-name
E: tuna: extended-description-is-empty
E: tuna: maintainer-name-missing uni@vrsal.xyz
E: tuna: missing-dependency-on-libc needed by usr/lib/x86_64-linux-gnu/obs-plugins/tuna.so
E: tuna: no-copyright-file
E: tuna: unstripped-binary-or-object usr/lib/x86_64-linux-gnu/obs-plugins/tuna.so
Lintian finished with exit status 1
The file tuna.so is created in the corresponding folder but tuna does not appear in obs :(
Thank you in advance :)
And when i try install it con with sudo apt install ./ say this:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'tuna' instead of './tuna-1.9.1-linux-x86_64.deb'
The following NEW packages will be installed:
tuna
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/12.3 MB of archives.
After this operation, 32.3 MB of additional disk space will be used.
Get:1 /home/naruto/Downloads/tuna-1.9.1-linux-x86_64.deb tuna amd64 1.9.1 [12.3 MB]
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package tuna.
(Reading database ... 148737 files and directories currently installed.)
Preparing to unpack .../tuna-1.9.1-linux-x86_64.deb ...
Unpacking tuna (1.9.1) ...
Setting up tuna (1.9.1) ...
But when i start obs, tuna is not in obs
I made a video showing it
Maybe this isn't as common of a problem, but I can't get the "Song info outputs" thing to work.
I go to "Add new"
I let it make a Song info path, and I enter in {title} just as it says to.
However, after clicking "ok" it's as if nothing happened. The song info output doesn't appear despite the program making the txt file on my computer. When I go to open the txt file, all it says is "No song playing" but those words don't show up in OBS.
I'm on a Windows computer and have followed the directions to use the YouTube Music plug-in. (The port is open and the plug-in is turned on in the Youtube Music app)
I'm open to suggestions. I don't think it's the YT music plug-in not working, but I won't know if I can't get this part to work.
Thanks!
ah, because it is bound as a scene true
Can I somehow fix it manually until the new version comes out?
Log into github and download the windows installer at the bottom https://github.com/univrsal/tuna/actions/runs/3839268322
I go to "Add new"
Thanks!
Post your obs studio log file after going through all those steps and a screenshot of how you configured the output before clicking ok
The log says you have 16 outputs configured, so I don't know where your problem is. They're most likely there, but you can't see them because your screen is too small. This is what the list is supposed to look like:
If the file is created you still have to add it to obs as a text source.
Okay strange, I can't seem make the screen any bigger, though. I've dragged my cursor around where the output box is but I'm not seeing it change to where I can expand it lol. It's been that way since I first opened Tuna. I appreciate the help!
I tried moving the window onto my drawing tablet (Basically a 2nd monitor) and I was able to make the window bigger! You're right, all the outputs were there! Thanks again :))
