vst 2 plugin graphic interface display size problem
Daikenzo
some GUIs are no longer displayed correctly in version 31.0.3 (e.g. vocalsynth). the size is too small to display everything.
Likely, scaling issue for High-DPI display devices.
It is better to re-test it against newer OBS: https://obsproject.com/forum/threads/obs-studio-31-1-beta.186286/
For the test purposes you can make OBS portable in a different folder. For portable OBS, please read only after the words "If it was not clear": https://obsproject.com/forum/thread...»-when-opening-app-settings.82157/post-346499 or in the Help: https://obsproject.com/kb/portable-mode
