Weird Audio loop issue with OBS recently .. please help
samurai_X
greetings all ..
i have been streaming for the past 3 years with no issues with OBS what so ever ..
got everything set as planned and everything was working fine till recently
i had to format my PC and move to another one
so i saved my settings and all stuff to move to the other pc
windows fresh install .. OBS fresh install .. everything clean and new
stopped streaming after finishing things up with no testing for around 8 months
came back yesterday and faced a weird issue of Alerts Audio looping
when alert plays everything came just fine from streamlabs
but after the visual alert video finishes the Audio Keeps looping for eternity .. tried to close all browse windows .. muted all sound resources in OBS .. made sure Audio shuts down when no video plays .. montoring in all audio resources are turned off .. but still nothing worked
the Audio keeps looping non stop .. the only way to shut it down is to close OBS totally .. which interupted my stream badly
whats going on
none of that happened before ever
i checked all links
i even refreshed them and pasted them again in a new source if old source was bugges somehow
made sure all alerts on stream labs finish on thier right time
nothing was wrong as far as i saw
plz assist .. i dont want to remove my alerts for thier weird Audio bug
Tell me, are there any other programs involved with your PC audio? One time, I used Voicemeeter Potato (digital mixing console for PC; not meant to be advertised) and I accidentally clicked "Monitor Only (mute output)" and there goes an infinite audio loop. If you use other programs, tell me, and I'll tell you a few possible causes of your audio loop issue. Happy to help!
first of all thank you for the reply ... as far as i am consirened opening the task bar there is only IFI Control panel and that doesnt do recording and anything .. my MIC is connected to the Rodecaster pro 2 .. my headphones are connected to the IFI zen3 and both connected to the PC via seperated USB ports .. i checked all monitoring off in OBS .. but seem that solution didnt work .. even checking the " Stop audio when no visual appear " option on the source .. still no use
what makes things worse .. i remember this issue happening before as well after a certain OBS update " dont remember when "
and didnt have RODE caster 2 back then if ur suspecting it .. but still if u r and u know a fix for it ill take anything to get rid of this infinite loop
whats going on
This normally happens when you're monitoring the audio and the audio monitor is the desktop audio, or (most probably) you're watching the stream without muting the player.
A log file from one of the streams affected with this issue is also needed. Please take a look at the pinned post on this forum.
I am currently having the same weird audio loop. Stream can't hear it, but I can, and it won't stop until I close down OBS. I have only been streaming for a month, and not very tech-savvy, and I don't know how to stop it/fix this bug. Has anyone had the same issue and managed to fix it.
