I like your plug in but...
It is normal that the browser panel alone use 20-25% of my CPU?
Even when the title are not shown.
(While streaming and recording at FullHD resolution my CPU use 10%)
This look very strange to me. And make the plugin unusable in production situation.
Thanks for your extraordinary job! I didn't understand how to use hotkeys to call the individual slots. I can activate and deactivate Lower Third 1,2,3 or 4. But if I want to start directly Slot 3 of Lower Third 1, I can only display the Lower Third 1 and not the slot 3. I am attaching a video to explain to me:
Hi, It seems that the Hotkeys are overlapping.
Try a key combination that doesn't include any other combination. (eg. Ctrl+Shift+Alt+1 includes Ctrl+Shift+1).
An option could be Ctrl+Shift+1 for LT1 and Ctrl+Alt+1 for Memory Slot 1
Hope it helps you!
i have a problem with the fonts, i uploaded the font succesfully but after a couple of times i activate the lower thirds, the font just resets and the custom font is still selected but the text is in standart font.
to fix it i have to re-add the custom font
these are the settings, i have it enabled as you see, but it doesnt work after a couple times of use.
Custom fonts only work with Google Fonts. You cannot use system fonts.
if not your case, what font are you trying to add?
Can someone help? My Lower Third 1, 2, 3 and 4 sections show up red. I'm using windows. Have done everything by the tutorial.
Where's the problem? Thanks.
Hi! It could be many things.
Have you added browser-source.html file to the scene? Have you turned on the Main Switch?
Hello! There's very little left to publish Version v1.6. And in addition to many other new features, the code has been rewritten with the main purpose of solving the performance of the tool.
I hope that with these changes you notice the improvement. ^^
I'm having a problem. I have followed all procedures. when I activate main and lower third 1, but the animation doesn't appear. I have written the name in the column. What is the problem? thank youView attachment 65734
I tried to get the same behaviour somehow, but the only way I get this is when I put in wrong size informations (see yellow circles) so that it is shown outside the visible frame. Does the timer (red) start when you activate LT1?
Thanks for reply, i hope the 1.6 will be out soon. Thanks for your work. I will donate you deserve it.
NoeAL updated Animated Lower Thirds with Dockable Control Panel with a new update entry:
Style 3, more customization and better performance.
Hi everybody!
First of all, I would like to thank those of you who have contributed to the project with your donation. Remember that you can support the project by making a donation by PayPal. I'll be very grateful.
And also especially thanks to David Plaza, a great collaborator who has helped a lot so that this tool can grow much more.
These are the new features:
- Improvements in design and performance of the UI.
- Global settings ordered by tabs...
Plugin isn't working with any images for me. The plugin and control panel itself work, but I've tried multiple images. None work?
Thank you NoeAL for this new version. Makes the tool again more flexible and user friendly. The tool's controls also seem more responsive. Is that possible?
(Don't forget to add a 'System' theme option at some time....) :-)
Hope it helps you!
Perfect! Now it works as I expected. Thanks
NoeAL, I'm hearing back from a few creators that the LUA script that powers the hotkeys returns a permissions error. What do you think is causing this prompt?
  1. Could it be a PC user permission issue?
  2. Could it be the result of the code trying to do something against the will of the PC?
My goal is to provide a solution for these users.
still any ideas? I´d love to have the hotkey available but cannot get over the annoyoing permission....
[lower-thirds_hotkeys.lua] Failed to call hotkey_pressed for hotkey_pressed: ...ugins/Lower-Thirds/lower thirds/lower-thirds_hotkeys.lua:436: C:/Program Files/obs-studio/data/obs-plugins/Lower-Thirds/common/js/hotkeys.js: Permission denied
