[lower-thirds_hotkeys.lua] Failed to call hotkey_pressed for hotkey_pressed: ...ugins/Lower-Thirds/lower thirds/lower-thirds_hotkeys.lua:436: C:/Program Files/obs-studio/data/obs-plugins/Lower-Thirds/common/js/hotkeys.js: Permission denied
This tool is not a plugin so I think this folder is not the best location and it seems to produce some permission error.
Can you try to put the Lowe-Thirds folder in other place, for example in the Desktop o C:\tmp, and try if in this location works well?
This is a great plug-in but very limited with only four instances.
Do you have any quick notes for altering the code to increase this?
Hello, we would like to add more LT but at this time it is not possible.
I remind you that even though there are only 4 LTs, each one has 10 slots, which means that with the same configuration you can have 10 texts and images for the same LT.
I don't know if this can minimize the fact that you need more LT.
Thanks for your contributions!
Hello - did the upgrade - like the new features. Unfortunately, lost the separator line between the image and the text lines. Where/which file should I look to regain that line?
For the time being, I've reverted to 1.5, so not time stressed on a solution.
Thank you for all the effort on this Dock and feature. It has been very useful. :)
[lower-thirds_hotkeys.lua] Error calling script_load: ...mated-Lower-Thirds/lower thirds/lower-thirds_hotkeys.lua:436: C:/Program Files/obs-studio/Animated-Lower-Thirds/lower thirds/../common/js/hotkeys.js: Permission denied
I have loaded this script from within OBS (with full path) and also created other folders on the C drive and keep getting this message. This is a work computer and our I.T. folks have given me admin rights. I have restarted the machine and OBS, deleted and re-installed the script, all to no avail. Any idea what permission I need to enable?
Thank, everyone for any help you can provide!
Hi! First, try to export the data so as not to lose your settings. Then Reset all the data and refresh the browser source (right button over the browser source, properties, click on "refresh cache of current page").
Test if it has been fixed, even restarting OBS. If so, try to import your data again and if it happens again with your settings, send me the TXT file to see where the error is.
Hope that helps.
The error shown is with the Lower Thirds folder within OBS directory. Could you put the Lower Thirds folder directly on the desktop, import the dock and browser from this folder on the desktop and see if the hotkeys work?
Which OS are you using?
Hi! Try to open OBS as admin (right button and click "run as administrator"). Tell me if it keeps happening.
Thanks for the input! Our I.T. created a local admin account for me. I thought I was running OBS as admin but apparently there is some confusion with that. Everything seems to work now, but I'll need to iron out the admin settings because when I am logged in as admin I have no access to all the files I need to get the project going!
I had tried that without luck, but it was an issue with my admin rights. Things work now but the permissions still need to be worked out. Thanks!
Thanks for the very useful accessory!
Over the last few days, I’ve redesigned the 3rd style a bit to make my own idea a reality. I only got a basic understanding of HTML and CSS programming, but I succeeded.
The structure of the code is a bit complicated for me, so it took me a long time to find what to modify. Is it possible to have a completely empty style in the next version? We can easily change the look and animation of this. The styles created in this way could also be shared here and the best ones put into the next version.
I can not get this to work. Initially I was getting the "permission" error but after I moved it to the documents folder and set OBS to run as administrator I am no longer getting an error message but none of the Thirds turn blue when clicked on, they all stay red.
hola tengo problemas con una pequeñas rayas que aparecen cuando se activa el 2o y 3er lower third muestro imágenes, cuando inicias con el 1o no aparecen , cuando desactivas el 1 y enciendes el 2 aparece 1 y cuando activas el 3o aparecen 2 . es insignificante pero al final de cuentas es un error
The fields name and info are required to show de LT. Could you check if they are not empty?
Hi
i dun really understand how memory slot works, anyone has more examples /video on this option?
Memory slot give the possibility to have 10 differents NAME, INFO, LOGOS for one LT. Fox example, in one team of basketball, you can enter all the players name's in the same LT (same configuration) in each slot.
Actions:
- To save something in one slot you have to write name and info and then click over the desired slot.
- To load slot, click over slot with number.
- To remove one slot, keep slot pressed until becomes red.
And that's it, you can view slots in action in this video https://www.youtube.com/watch?v=nKcvu-HwP9k&t=176s.
Hope this helps!
