Poltergeist: Remote Control Overlay & Mod Tools
Heek Development updated Poltergeist: Remote Control Overlay & Mod Tools with a new update entry:
Chatbot Clips & Custom Widget
Twitch Auto-Clipping & Dashboard Polish​
A new clip command was added to the chatbot and the custom code widget no longer shows CPU lock when going to a different tab
  • Auto-Clipping: You can now create automatic Twitch clipping commands (like !clip) directly in the Chatbot Builder! Just check the "Create Twitch Clip" box and add the {clip_url} variable to your bot's response to instantly drop the clip link in chat.
  • Custom Widget Stability:...
Kick chatbot
Kick Chatbot Integration​
Kick broadcasters who have the broadcast suite can now fully utilize the Chatbot Builder!
  • Custom Commands & Timers: Build custom chat commands, set up automated looping messages, and configure mod-only triggers that reply natively in your Kick channel.
  • Chat-Driven Games: Your viewers can now interact with the Prize Wheel and Carnival Booth directly through Kick chat using commands like !spin or !throw.
The...
Moderator "Soft-Locking"
Moderator Limits Revamped​
Moderator limits have been completely updated for expired Broadcast Suite subscriptions and 7-Day Trials. Previously, reverting to the Free tier (which has a 1-moderator limit) meant the system automatically deleted any excess moderators. This proved to be a frustrating experience.
No More Deletions​
Moving forward, excess moderators are no longer deleted. Instead, they are simply placed in a locked state. A red LOCKED...
Trigger Studio
Trigger Studio: Put Your Viewers in Control​
Trigger Studio is a brand new automation panel that turns viewer activity into automatic on-screen moments. Map an event to an action and it fires by itself, with no moderator needed. Open it from the Trigger Studio button in the right sidebar, name your trigger, pick what fires it, then pick what happens on screen.
  • Fires from anything: Channel Point redemptions, Bits, Subs, Gifted Subs, Raids, or...
